Cluster Lights Not Working!
I swapped my stock cluster for the the ex cluster with Tach. After hooking everything back up my background lights will not turn on. I checked the fuses (fine) and all correct light bulbs are in.
What next?
Thanks
What next?
Thanks
Re: Cluster Lights Not Working!
Pull out your trusty multimeter.
Remove the dimmer switch and uncouple the connector. With the combination switch turned to parking lights, do you measure 12 V on the red wire to body ground? Does the black wire have continuity to ground?
Also, is fuse 19 under the dash blown? Does fuse 19 have battery voltage?
mark11017
09-27-2010 09:17 PM
millertime1388
12
09-08-2010 07:59 PM
kc_boss_816
24
07-27-2010 07:38 PM
LOLyouhavefakewheels
11
02-01-2006 07:28 PM
