Civic Timing Belt Replacement Question
my 98 ex coupe has 1022xx miles i'm pretty sure i need a timing belt replacement...just exactly what mileage are you suppose to change it? and i'm kinda short on funds..so would it be alright if i drive to like 103k? THANKS
Re: Civic Timing Belt Replacement Question (N~FaMouSKhMerBoi)
cause right now it doesn't feel like its a full strength..and would i be able to tell a difference when i change it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N~FaMouSKhMerBoi »</TD></TR><TR><TD CLASS="quote">cause right now it doesn't feel like its a full strength..and would i be able to tell a difference when i change it?</TD></TR></TABLE>
There will be no difference, but if it breaks you're screwed. I'm pretty sure that the Z6 and Y8 are interference motors.
edit: Get a Helms.
edit: Get a Helms.
Re: Civic Timing Belt Replacement Question (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">
edit: Get a Helms.</TD></TR></TABLE>
what's interference motors?
Supposed to replace timing belt and inspect water pump every 90k under normal conditions and 60k under severe conditions. As far as waiting 800 miles to change it out, you will probably be fine, might want to inspect it though for cracks and wear though.
Re: Civic Timing Belt Replacement Question (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC »</TD></TR><TR><TD CLASS="quote">Supposed to replace timing belt and inspect water pump every 90k under normal conditions and 60k under severe conditions. As far as waiting 800 miles to change it out, you will probably be fine, might want to inspect it though for cracks and wear though.</TD></TR></TABLE>
I think the book says 105,000 for timing belt and water pump.
Re: Civic Timing Belt Replacement Question (RyanCivic2000)
Oh excuse me, forgot to mention this was the quote for a z6 via the helms, not that it should matter, gonna be just about the same.
I guess I should have been more specific as well, I got my number from the owner's manual for a Y8. Either way I would probably do it at 80 or 90,000 anyways just becuase of what was mentioned before about the Y8 and Z6 being interference motors.
Remove the valve cover and upper timing belt cover and inspect the belt. Most people recommend replacing the belt at 90k miles. The helms manual says 60k under severe conditions and 105k under normal conditions.
you'll be fine going to 103k as long as the belt isn't in **** condition. If it looks dry or cracked, replace it, regardless if you are at 90k, 105k, or 30k. If the belt breaks while you are driving.... kiss your valves goodbye. quick fix, just go to your local parts store and get the belt. Good Luck
Re: Civic Timing Belt Replacement Question (kommon_sense)
Slightly off topic, but how bad is it to leave your upper timing belt cover off? I had to because of my adj. cam gear. I keep my engine bay really clean, it seems unlikely something would get caught in the top.
GSE980
54
06-19-2007 11:18 PM
kai-chun
09-05-2006 01:09 PM
00siandrew
07-20-2006 10:13 PM
*Boostwerks*
06-25-2005 11:17 PM
