Timing belt question for em1...
How often should the timing belt be changed on these motors? Im coming from owning 2 dsm's, so Im a little **** when it comes to timing belts.
Re: Timing belt question for em1... (00siandrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00siandrew »</TD></TR><TR><TD CLASS="quote">How often should the timing belt be changed on these motors? Im coming from owning 2 dsm's, so Im a little **** when it comes to timing belts.</TD></TR></TABLE>
All hondas are recommended to change them @ 90k intervals. Be sure to change the water pump at the same time, even if it isn't needed....will help later down the road.
Re: Timing belt question for em1... (Built Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boomer234 »</TD></TR><TR><TD CLASS="quote">i think honda recommends every 100K miles
you can also do a visual check on it by removing the valve cover and see how tense it is, if its fraying and so on...</TD></TR></TABLE>
I personally wouldn't trust the check method. A belt can look alright one oil change and then the next be screwed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built Beast »</TD></TR><TR><TD CLASS="quote">
All hondas are recommended to change them @ 90k intervals. Be sure to change the water pump at the same time, even if it isn't needed....will help later down the road.</TD></TR></TABLE>
This is correct 90k. People have gone longer and had no problems, I personally have seen my friends sisters civic go to 150k before it was changed. Just depends on how the car is driven also I belive.
GSE980
54
06-19-2007 11:18 PM
2camsaam
07-30-2003 12:20 PM
