Civic SI guage cluster!
i was wondering if the SI guage cluster will hook up directly after i pull out my stock CX cluster in a 1996 EK. even though there is no tach on the cx, is there a plug back there to hook up the SI cluster. i also really need to know a place that cna order the SI cluster. thanks alot
Re: Civic SI guage cluster! (tyflip2)
You would probably have to check the recycler.com or thepartstrader.com for a cluster.
Buts its a simple plug and play mod. There are 2 screws holding your bezel on (at the top) and 2 clips at the bottom. Then onces that is off there are 4 screws holding in your stock cluster, remove those and then there are 2 wire connectors on the back of the cluster. Take those out. And intall the si cluster.
Mr Boston
09-06-2003 10:00 AM
