civic si code 22 what to do to fix this
hello guys i have a 00 civic si with a b20-vtec supercharger and i´m going nuts with the car since i keep getting code 22 which is the vtec switch.. i triple the oil pressure and its good, i also get for power on the line and its algo good. i removed the solenoid and clean it and install again and the same problem keeps coming out.. i also change the entire solenoid with switch for another one and the same problem stays.. can you guys help me out to fix this problem, when i reset the ecu the vtec works fine but after minutes of resetting the ecu the code comes back.. and the vtec shuts off any idea.. than x
Re: civic si code 22 what to do to fix this (sytema)
is the ecu chipped? have you tried another ecu to see if it is a consistent problem regardless of ecu? just curious....
Re: civic si code 22 what to do to fix this (DJ_SaNdOz)
yes i did try stock ecu and the problems comes out again, and the wiring for the vtec are on the right pinout. i also have a apex vtec controler but everything was connected right, and also triple check that but the same problem any ideas?
RoaringTurtle
18
08-05-2002 01:17 PM
