Where does the ECU get the signal to throw CODE 21?
Old Jul 26, 2006 | 10:44 PM
inline4's Avatar
Default Where does the ECU get the signal to throw CODE 21?
How does the ECU throw a code 21? The VTEC solenoid is just a switch and not a sensor, it doesn't give feedback to the ECU, so how does it sense if the VTEC solenoid is bad or hooked up wrong?
My Vtec pressure switch works perfectly.. well i'm jus trying to fix this problem..
https://honda-tech.com/zerothread?id=1702022
Old Jul 27, 2006 | 01:40 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Where does the ECU get the signal to throw CODE 21? (inline4)
I would imagine it can tell from the VTEC pressure sensor. If the VTEC solenoid engages, then the VTEC Pressure sensor would see an immediate change in oil pressure at that location. If it doesn't, it throws a CEL.
Just a logical guess.
Old Jul 27, 2006 | 03:05 AM
inline4's Avatar
hhaha,, stupid me. turns out that pin A4 at the ECU wasn't making contact with the ECU. lol.. all this time, troubleshooting and tracing wires, and trying everything turns out to be the stupidest thing ever. all I had to do was take pin A4 out and push in a little metal tab on top of the pin so that the ECU pin would make contact.
9WON4
Jun 2, 2006 06:11 PM
VTC_CiViC
Nov 17, 2004 09:05 PM
311
Oct 8, 2002 11:42 AM
RoaringTurtle
18
Aug 5, 2002 01:17 PM
