Civic motor swap
Civic motor swap
OK, please dont flame me for what i am doing, but there are reasons. I have a 99 civic si. I am taking out the bad b16a2 engine, and replacing it with a SOHC 1.6 from a 99 civic ex. I have the whole car, and just need to know which motor mounts to use, and also what axles to use. Anything else i may need to know would be extremely helpful,
except for "what are you thinking..."
Re: Civic motor swap (guy5978)
use the same mounts. you need a rear bracket from a 99-00 ex. i don't believe the b16 bracket will work. and you need 96-00 D series civic axles.
also the b16 header won't work. you need one from the SOHC.
Location: ....................................................................................................
wow downgrading im not being dick but whats wrong with that motor? rod knock? rings?
Re: (mcvtec)
I tried the p2p ecu, but doesnt work right. there is still a harness coming from the dash side of the car, that was plugged into the old ecu, but there is no place for it on the new ecu.....Is there a difference between 98- and a 99?>
Seagull Management
Re: (guy5978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guy5978 »</TD></TR><TR><TD CLASS="quote">Is there a difference between 98- and a 99?></TD></TR></TABLE> Yes, '96 - '98 ECUs use different plugs than "99 - '00 ECUs, you might be able to get a jumper harness though.
jr13music
02-06-2014 04:42 PM
SiB16A
11
09-27-2005 07:00 PM
