Civic D15B 3 stage Vtec hesitant on low rpm.Help..
#76
Re: Civic D15B 3 stage Vtec hesitant on low rpm.Help..
What kind of engine harness are you using? Are you aware you have an OB2b ecu? Do you have any sort of check engine codes? Your D15B 3 stage vtec engine, is the engine complete or did you just take the 3stage head and place it on some other engine? Have you adjusted the valve lash on this engine?
#77
Hey I don't know if this might help you but I found one of my problems the ground cable that goes connected from the tranny to the body of the car was really corroded and after I change that one and the one that goes from the valve cover to the body of the car it was running a little better only for $10 for but cables not bad you should try it, next it will be fuel pump walbro 255 maybe next month.
#78
So, OP have you tried to diagnose the EGR? Have you remove the egr? Maybe try to test it to see if the solenoid is stuck or sticking? Have you cleaned the EGR chamber on the intake manifold if there is one? I have a Civic HX but it has electrical problems due to being hotwired and I'm not sure if that's a good platform to compare to.
#79
when i disconnect the hose that goes to the egr nothing seems to be affected even when i unplug the egr wire and drive it there is no cel on.....
#80
#81
your egr valve could be stuck open . this will cause a rough idil and hesitation if you have access to a vacuum pump(you can also just bypass the egr solenoid put manifold vacuum directly to the egr ) with the engine idling if the valve is free it should run really rough or stall completely if there is no change it's probably stuck or full of carbon .
#82
also if the icm is failing in the dizzy it could cause problems also does it break up under load at higher rpm or just below 3000 rpm ?
#83
also I have an electrical issue ... my headlights and gauge cluster get brigther when accelerating or keeping a constant speed, and then when braking/at idle, they dim back down, I had the alternator and battery changed and both are in good working order, any other ideas?
#84
i'll try the egr test and it will let you know.But most of the time the idle seems fine,it happens mostly during hot weather or in traffic...
Concerning the icm it has been replaced and there is no improvement,it hesitates only in low rpm.
For the dimming issue,the headlight seems to light normal there is no dimming.only the interior lights dim when i accelerate below 3500 rpm.I'll check the dash wiring too.
#85
I was having some idling problems for the past two weeks it was idling from 1000 to 1500 RPM so I decided to clean the IACV took it off and clean it with brake fluid I forgot to check if I could move the valve but I installed back in and it was idling at 600 to 700 RPM it worked so I decided to beat the **** out of it in the highway since it was running so good lol I was shifting at 7500RPM everytime I was doing at least 100 and the ****ing check engine light came on and I couldn't rev it pass 5700 RPM tempeture was good and everything was good I opened the hood and the top radiator hose looked like if it was going to burst I was thinking well maybe because the stupid headers need to get heat wrap because it gets really hot inside the engine bay, so I did some new connections to run the fan all the time as soon as I start the car after I was done the check engine light came con and the idling problem came back this time I checked the bottom hose and it was cold when the top one was getting a little to hot so tomorrow I'm changing the thermostat that should fix that problem and check if the idle was bad because of it or maybe I have air in the cooling sistem, by the way have you check compression on the cylinders? now insted of having the problem to rev it up to 3000 rpms now is just 2000 rpms maybe I'm doing something good lol I was about to connect the vtec so it can open from 1000RPM that will give it a little torque on the hills lol but that won't be so good on gas, well still looking to see what the main problem could be on the lack of torque from 1000 to 2000 rpms.
#86
I've not yet done a compression test...you need to check your radiator.maybe its dirty inside....
#87
Yes I think compression check should be a good idea, I need to do mine too, today I change the thermostat, I just ask my self if we ever going to find the problem on this **** well I have a few more things to try but everything is $$$$$ maybe if I turbo this maybe boost will help with the compression at low rpms who knows.
#89
I want to say cam timing or over adjusted valves. Have you had the head milled? Mill the head a lot can cause cam timing to change and needs proper adjustment. The other thing that comes to mind it maybe sticking valves. Have you done a compression test??
#92
#93
GnrlKll
40
08-06-2012 08:20 PM
