chipped p28 ecu works in d16z6 engine?
Re: chipped p28 ecu works in d16z6 engine? (rebohn)
It will work, but if it's chip for a dohc b-series then it will run rich...You can get a fuel pressure regulator to turn down the fuel a little....
yes i dont know why check engine light on chip shunk2 kick 4,400 8,800 rpm its possible chip type? what recommend
Check the code on your check engine light. It would probably help if you read more on chip tuning. I would not recommend posting anything there but try reading as much as possible to help you out..
http://www.pgmfi.org
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebohn »</TD></TR><TR><TD CLASS="quote">yes i dont know why check engine light on chip shunk2 kick 4,400 8,800 rpm its possible chip type? what recommend </TD></TR></TABLE>
engrish?!what did you just say?
there's no reason it won't work on a Z6,although it's not the optimal program.main thing is be careful of the high rev-limiter.
chris
chris
