checking and correcting your tps??
Checking and Correcting your TPS??
yeah my tps(throttle positioning sensor) is off and my car revs up and down due to the problem..does anyone know how to check it? and fix it? please help a.s.a.p. thanks brett..
Guest
Posts: n/a
Re: checking and correcting your tps?? (d16y7vtec)
could you do this?
Disconnect throttle position sensor wire connector.
Using an analog ohmmeter and feeler gauge inserted between throttle lever and stop screw, take the following resistance measurements:
With throttle closed, measure between terminals VTA and E2. Resistance should be 200-800 ohms.
With throttle lever and stop clearance of 0.0197 inch (.50 mm), measure between IDL and E2. Resistance should be 0 ohms.
With throttle lever and stop clearance of 0.0354 inch (.90 mm), measure between IDL and E2. Resistance should be infinity.
With throttle valve fully opened, measure between VTA and E2. Resistance should be 3300-10,000 ohms.
With throttle valve in any position, measure between Vcc and E2. Resistance should be 3000-7000 ohms.
If switch fails to operate as specified, adjust switch as follows:
Loosen switch attaching screws, then insert a 0.0197 inch (.50 mm) feeler gauge between throttle lever and stop screw.
Connect ohmmeter between IDL and E2 terminals.
Rotate switch clockwise until ohmmeter deflects.
Tighten attaching screws, then repeat step 2.
If switch fails to perform as indicated, switch is defective.
Re: checking and correcting your tps?? (Spade)
How about in idiot format?
Re: checking and correcting your tps?? (IM ALL SHO)
humm i think i guess i can do that.. what do i put the ohmeter at to read? there is all different settings..i might just get a new one.. that might be a lot easier..
so now i find out you cant get the sensor separate from the throttle body.. what should i do? anyone have a throttle body for me?
gabrielsousa
16
11-25-2015 10:02 PM
092eg6
04-08-2010 05:04 PM
saviour250
03-14-2009 03:42 PM
