TpS Sensor gives negative readings
Old 03-10-2009, 10:24 AM
saviour250's Avatar
Default TpS Sensor gives negative readings
Hi I have an issue with the TPS sensor. It is giveing Negative READINGS.
like 5 volts on power wire
0-0.2 volts on ground wire
0.5 volts at closed throttle to 4.5 volts
but in negative for ex -5volts my honda is a japan import and i had bought a skunk2 throttle body from U.S I Think its a R.H.D to L.H.D issue cause my mech had tried it with 2 diff multimeters 3 throttle bodies and 2 Tps sensors. the car works fine just negative readings on the new throttle body. Any help will be appricated thx
Old 03-11-2009, 02:15 PM
Pure Sol's Avatar
Default Re: TpS Sensor gives negative readings
Sounds like you have the leads from the multimeter backwards. I know on mine if I put the Neg lead to a positive source it will read a negative voltage.
Old 03-12-2009, 02:22 PM
saviour250's Avatar
the multimeter reading is fine cause my mech tried it with 2 diff multimiters and 3 throttle U.S bodies 2 Japanies and 1 and 2 tps sensors. The Jap Throttle bodies gave positve readings while the U.S throttle body Skunk2 70mm gave negative readings.
Old 03-12-2009, 02:24 PM
Hanmin's Avatar
just switch the toothpick things around, then it'll read positive again. The tps is fine. I've never heard of a japanese tps sensor reading opposite.
saviour250's Avatar
To be more accurate
My car is a Honda Del Sol SIR japanese import. The engine is a B16, the ecu for now is an obd1 but i bought an AEM EMS cause i made a turbo upgrade, the throttle body is a Skunk 2 70mm
My mech has done the test on 2tps sensors (both japanese) and 3 throttle bodies (2japanese and 1 U.S)
when he uses the jap throttle bodies the readings are with in
4.5 volts.
readings:
0.5 volts at closed throttle to 4.5 volts at WOT on the signal wire.
when he uses the U.S throttle body the reading are with in this range but negative like
-4.5volts
The car performance isint affected it works fine
maybe cause its right hand drive not left hand drive? even the throttle cabel is different
Old 03-13-2009, 02:44 PM
Hanmin's Avatar
I don't think even you know what your talking about.positive or negative, it doesn't matter. as long as it's 4.5 and .5. Unless, by a rare rare, never heard of before chance. that honda, released a car, with a major tps defect. other than that then no need to worry.
Old 03-14-2009, 03:35 PM
saviour250's Avatar
Thats why i posted this question cause it is very strange that it gave me the readings in negative and i wanted to know if some one had the same problem. The thing is that the car works fine.
Old 03-14-2009, 03:42 PM
HRD PKR
B16B_coupe's Avatar
Its prob the settings you using while testing
wiki
Honda Civic (2006 - 2015)
10-18-2021 09:00 PM
092eg6
04-08-2010 05:04 PM
92prelude23
01-26-2009 05:43 PM
GSRcivicGSR
12-20-2004 04:29 AM
Redsim
06-11-2003 09:37 PM
Quick Reply: TpS Sensor gives negative readings
