CHECK ENGINE: VTECH SOLENOID 99-00' SI
Old 12-21-2009, 02:30 PM
New User
emone.kid's Avatar
Default CHECK ENGINE: VTECH SOLENOID 99-00' SI
OK. I am unable to figure this out myself, so maybe someone with experience pertaining to the thread could help me out.
For about 3-4 months I've had my check engine light running for my vtech solenoid and just recently I decided to replaced my vtech solenoid on DEC 18th and have put close to 300 miles on the new/used vtech solenoid and still the check engine light is running. My car now red lines at about 6 and half grand since the problem occured 4 months ago and seems as if there's no end to the ever evolving problem...
To add to that, the car is also experiencing a little back fire and bogs every now and then. I was assuming maybe the timing on the distributor may be off slightly. Any suggestions?
I also, recently upgraded a few parts: DC HEADERS[NEW], MAGNAFLOW HI FLOW CAT[NEW], and BOSCH 02 SENSOR[NEW]
Maybe, the car needs to be tuned?
BTW the odometer reads 71,000. So, why so many problems?
HELP ME PLEASE!
LOL
Old 12-21-2009, 02:43 PM
WeakSauce92's Avatar
Default Re: CHECK ENGINE: VTECH SOLENOID 99-00' SI
Did you call customer service?
I've never had this problem (yet) and haven't really been with my honda that long, but after reading around on the forum, I would say try cleaning your iacv/grounds to try and help the bogging down. I just hope someone that really knows can correct me and help you out. GL
Old 12-21-2009, 03:16 PM
roadsqueegy95's Avatar
did u reset the ecu after you replaced the solenoid?
Old 12-21-2009, 08:32 PM
LSVTECKID's Avatar
VTECH!! Making phones since 1994.
Old 12-22-2009, 07:49 AM
New User
emone.kid's Avatar
LMAO ... TYPO TYPO TYPO ...
i haven't ad the time to call, i just told you there something wrong with the VTECH. lol.
Old 12-22-2009, 07:50 AM
New User
emone.kid's Avatar
yea, i removed the ecu and disconected the battery. still nothing...
Old 12-22-2009, 01:13 PM
barone's Avatar
ok i had the same problem as you. i got a 00 civic si with 77thou miles. i went through everything with mine. had the same crap as you. it goes into limp mode and wouldnt let me go pasted 6500rpms. first i thought it was the vtec plug loose, i tryed the silnoid, pressure switch, cleaned the silnoid screen before replaced it. u can check to see if yours is working right by splising the wire and taking a wire to that and the battery and everytime u hit the wire, the silnoid should click.
but one of my freinds freinds who works on civics all day everyday. told me it was my ecu and to get a stepdown and run a chipped 95ecu. so thats what i did and my cel went away and my vtec been ripping everysince.
people were telling me oil pressure and etc which would shut down the vtec. but i realized a day before i got my ecu. i would try this out on yours.
soon as i would start my car, my vtec would work until my car was warmed up and then it woud go into limp mode. which is werid because u shouldnt even rip ur vtec while ur engine is cold, i always wait till mine is warmed. but thats what i relized towards the end. i would look at that if i was you.
idk let me kno how it turns out
Old 12-22-2009, 01:45 PM
r22thomas's Avatar
I had this problem for along time.
When you replace the vtech solenoid you must also replace the vtech transceiver. The reason is because one is operating at 800mhz and the the other at 2.4ghz. By replaceing both they are both operating at 2.4ghz.
Old 12-22-2009, 03:05 PM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old 12-22-2009, 04:41 PM
Resident Gearhead
BryanM.'s Avatar
Originally Posted by HondaPartsHero
Originally Posted by EE_Chris
Look at that - a systematic way of figuring out why VTEC doesn't work. After reading so many of these threads around here, I was beginning to think visual inspection followed by randomly replacing parts and hoping for the best was how it was done.
Good post.
96lewd
09-27-2005 09:39 PM
cvccjdm
10-15-2004 06:16 AM
Web_Head
09-29-2004 08:25 PM
quiambao1180
08-06-2003 09:42 PM
Quick Reply: CHECK ENGINE: VTECH SOLENOID 99-00' SI
