Check engine light once again:(
well first off if you ride in vtec range not close to 7k but inbetween 5500-6500 can it make it throw a code?.......THis has happened before and i got it checked and it was vtec system malfunction and i reset my ecu havent had a problem since untill now. But now after the check eng. light came on if you go up to 6k the car sputters and about stalls out. What does this mean? what can i do to fix it?
I dont care about punctuation or spelling
Re: Check engine light once again:( (DSeriesBKilla)
i did....it came up to fuel/air metering and the code i forgot what it was p1259 somethin like that and it was VTEC SYSTEM MALFUNCTION so i know what it is but why do i keep getting this problem and why is it acting up at 6000 rpms?
Re: (smokinsi)
even if it is supposed to be more then 4 it isnt by alot and we just put it in there and i know it isnt burning that much oil and there are no oil leaks already got that checked.
