<<<<<<<<<<<<<< CHECK ENGINE LIGHT AFTER INSTALLING AEM SRI
Re: <<<<<<<<<<<<<< CHECK ENGINE LIGHT AFTER INSTALLING AEM
what is the cel code? there is a air intake temp sensor on the intake tube is that reinstalled and plugged in?
I can't check the code.. I'm not the best with stuff like that.
I did plug the sensor on the tube too.
Anyone else have any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaluwa3 »</TD></TR><TR><TD CLASS="quote">I can't check the code.. I'm not the best with stuff like that.
If you are not capable of checking the code, especially after following the instructions in the link provided above, then you should not be touching anything on your vehicle.
Please put down all tools and take your car to a qualified mechanic to pull the code for you.
I had the same issue with my 97 civic ex. I disconnected the negative terminal from the battery and let it sit for 30 minutes (10 minutes is normal) and then reconnected it. The light did not come back on. Doing this resets the ECU and enables the computer to adjust to the new part. Doing that MAY help but I'm not the smartest guy in the world. my .02
Nate
Nate
Re: (nato)
Will turning the key to the on position, but NOT actually cranking the car up cause the CEL to come on? I had the IAT sensor unplugged at the time and turned it to the on position, but didnt start the car.
yes that will cause the cel
be sure its plugged in, reset the ecu and the cel should be gone
seriously though...if you cannot follow that very simple step by step procedure, you shouldnt be doing anything at all with your vehicle...
Re: (kaluwa3)
Dude I dont know about hondas but my saturn ses light comes on before i actually fully turn car on!!!! So i guess its normal as long as it dont turn on while car is completely on or while driving then u have a problem Also my Light turns on ! on my 93 Civic !!!! it comes on with the battery and oil one right??!! Then its OK
Re: (kaluwa3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaluwa3 »</TD></TR><TR><TD CLASS="quote">Will turning the key to the on position, but NOT actually cranking the car up cause the CEL to come on? . </TD></TR></TABLE>
Cause the cel to come on and stay on till you start the car? or come on and go off after a couple seconds?
Re: (mortificationrock)
I just reset it by unplugging the battery. It was most likely because I turned the key to "on" with the IAT unplugged.
Thanks guys for the info.
And Pdiggitydogg.. I'm sure I could have done it if I wanted to, I was just asking if there was a simpler way
