Honda S2000 Honda S2000
Intake=Check engine light on
Old Nov 6, 2006 | 10:41 AM
nhinnhuckyduc's Avatar
Default Intake=Check engine light on
Does anyone know the code to turn off the check light due to the after market air intake, or know what i shloud do to get it turn off.
Old Nov 6, 2006 | 12:41 PM
WowOzYouRock's Avatar
Default Re: Intake=Check engine light on (nhinnhuckyduc)
try to resetting by disconnecting the battery for 2-3 minutes ... if it turns back on, do that "map whack"....
Old Nov 6, 2006 | 12:55 PM
Mr. Projekt's Avatar
* B A N N E D *
Check the EVAP unit's vacumm lines. Happens often with intake installs.
Old Nov 6, 2006 | 01:11 PM
Francesco's Avatar
Default Re: Intake=Check engine light on (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Check the EVAP unit's vacumm lines. Happens often with intake installs.</TD></TR></TABLE>
x2
Old Nov 6, 2006 | 04:07 PM
ottokrat's Avatar
Pull the code. It's probably a loose wire or something; the code will tell you which one. Go to Autozone and ask them to pull the code for you, if they're nice they'll do it for free...
Old Nov 6, 2006 | 04:09 PM
* B A N N E D *
Default Re: Intake=Check engine light on (ottokrat)
If the code pulls up "Secondary Air Injection System", I was right.
Old Nov 7, 2006 | 05:58 AM
gomarlins3's Avatar
Pull the code, get it fixed.
Old Nov 8, 2006 | 02:08 PM
iam7head's Avatar
Default Re: Intake=Check engine light on (gomarlins3)
probably the little vaccum line before the check valve(which seated next to the airbox) is loose, mine was loose when i install my spoon snorkel.
Old Nov 8, 2006 | 02:32 PM
* B A N N E D *
Default Re: Intake=Check engine light on (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">probably the little vaccum line before the check valve(which seated next to the airbox) is loose, mine was loose when i install my spoon snorkel.</TD></TR></TABLE>
EVAP system. Thanks for confirming my opinion.
LoGaN-VanG
Honda Civic (2001 - 2005)
Jul 1, 2009 08:18 PM
skaternak
Oct 29, 2008 01:40 PM
kaluwa3
16
Apr 25, 2007 02:30 PM
cp_harrington
10
Jan 25, 2003 06:43 PM
