Check Engine Light "ADAPTER" ! how to. . .
I thought about sharing this with you all to how to check your CEL's without looking for a piece of wire. It's simple to make and you can get it from any junkyard. You use the female end of the connecter from the bottom of the front driver seat. Under it is the connection for the seatbelt light on the dash. All you need then is a crimp cap and there oyu have it! A CEL adapter. . . here are some pic's for you so you know what it look for and how to make it. . .
Jeramy
Jeramy
Re: Check Engine Light "ADAPTER" ! how to. . . (jdmsol)
do what i did..... run two wires permanently from that plug to a push button switch. whenever a CEL pops up, hold down that button. hopefully u will never have to use it, but if u do u can check it without bending over the seat or breaking ur neck. cool idea though.
krazy
krazy
Re: Check Engine Light "ADAPTER" ! how to. . . (krazy)
krazy
krazy
Re: Check Engine Light "ADAPTER" ! how to. . . (nerdsports)
awww is it to hard for you guys to plug a paper clip in?
just use a prebent paper clip in your glove box along witha print out of all the codes folded up with all your insurance papers
Re: Check Engine Light "ADAPTER" ! how to. . . (FF-Panda)
Well i like the idea.
it is not too hard to use a paper clip/piece of wire etc.,etc. But hell I like this too.
krazy
krazy
Jeramy
Re: Check Engine Light "ADAPTER" ! how to. . . (flat-blk-HB)
isnt there a way you can hook up a LCD (or similar to your clock) screen that will allow you so that when you get a code, you can just look at the screen and it will show you in digital numbers what the code is... just like the CRX and Hatch ECUs?
Re: Check Engine Light "ADAPTER" ! how to. . . (WykidEH)
haha... before the swap it did. i used to get an occasional MAP CEL but i fixed that already. it was a bad PCV. its just handy. funny u say that, im my own mechanic sorta.
krazy
krazy
WOW! I like that Idea... I personally have a switch run into my glove box, but instead of tapping into the wires, i'd rather reach underneath my seat, cut that clip (Which is disconnected anyways), and move it over there, and crimp the switch wires to it...
THANKS!
THANKS!
Re: Check Engine Light "ADAPTER" ! how to. . . (ScrapinSi)
isn't there a connector to jump under the hood? one time i saw a honda-tech working on my car, and he unplugged a rubber cap from this connector and jumped it, and checked my timing.
Re: Check Engine Light "ADAPTER" ! how to. . . (tominos)
orrrrrrrrr you could put a switch inline of the diagnosis plug...just switch it over when need be.
did that
edit: not to self..read ALL of post before replying.
[Modified by B18EG6, 9:31 PM 2/11/2003]
did that
Re: Check Engine Light "ADAPTER" ! how to. . . (B18EG6)
i got an original one from a buddy of mine who works at a honda dealership, can post a pic if anyone wants to see it
Re: Check Engine Light "ADAPTER" ! how to. . . (frostdragon)
ok here are a couple pics, the plug is the same
im guessing this is the part # if anyone cares
Banned
Re: Check Engine Light "ADAPTER" ! how to. . . (blykins)
