mad electrical problems for a DA9
Old Jan 25, 2005 | 02:37 PM
DA9muthaFocka's Avatar
Default mad electrical problems for a DA9
yo my da got alotta electrical problems...windows,radio,clock,wipers, defrost, lights, tnohing works anymore.....car doesnt even run, needs a starter and battery keeps dieing.....have to jump it eveyr time until once we couldnt even do that so we had to compression start it but it still doesnt run......someone tell me whats wrong......pleaseeeeeee
Old Jan 25, 2005 | 02:53 PM
teg01's Avatar
Default Re: mad electrical problems for a DA9 (civichb5)
Lets take this step by step.
1. Check your fuses
2. Make sure none of the connections are lose
3. Make sure the switches are funtional
4. Make sure none of the wiring is bad
5. Woste case seniaor, replaced all the wiring.
-dead battery sounds like the alternator might not be charging the battery-
Take your car to autozone and have them check it out for free.
good luck
Old Jan 25, 2005 | 03:23 PM
tossnupweight's Avatar
what? info lacking. did it all happen at once? or was this step by step? what changed, wiring doesnt go out. how do you know it needs a starter? prolly just needs a battery. take it to a dealer or something or try and find someone who can help you out.
Old Jan 25, 2005 | 05:01 PM
HONDA_TYPE_R's Avatar
Default Re: mad electrical problems for a DA9 (tossnupweight)
Electrical gremlins are a nightmare. You should check your fuses for sure, as well as your ECU and chassis grounds. Wiring doesn't just get messed up...it usually takes something like an under hood fire to destroy it. You are probably having charging problems with your alternator though. I would definitely take it somewhere to have it looked at.
kevinEJ
Dec 30, 2010 05:08 PM
mrmcnotbuff
Oct 6, 2007 11:04 AM
CrX-To-Tha-Max-v2.0
Dec 1, 2005 06:38 PM
blackcivic44
Jul 9, 2005 08:54 PM
stlrexrider
17
Apr 28, 2005 06:10 PM
