car won't run with MAP plugged in
so i just installed my turbo kit and now my car will idle fine with the MAP plugged in, but as soon as i give it any amount of throttle, it immediately dies. i tried swapping the TPS and MAP plugs, didn't work. it runs with the map disconnected, but the idle is very crappy. it worked fine with my old ecu so what could it be? thanks for your help
Re: car won't run with MAP plugged in
no cuz it worked with my stock ecu. then i converted to obd1 with a stock d15b2 map set up for the dsm 450's i have installed and now it won't work. if i plug the stock ecu back in it works fine.
boostedcivicsir
07-24-2007 11:49 AM
boostedcivicsir
07-24-2007 06:17 AM
