Car pulling hard left? Help?
Old 04-21-2009, 01:23 AM
carcious's Avatar
Default Car pulling hard left? Help?
So tonight I was driving and my steering wheel began to vibrate, and the vibrations became a strong pull to the left.
The car is only pulling to the left so I'm pretty sure it's not rack & pinion.
Any ideas of what it might be?
Oh and I drive an EG hatch with an LS..not sure if that helps...
Old 04-21-2009, 04:57 AM
EricRyan's Avatar
Default Re: Car pulling hard left? Help?
Move your tires from front to rear, rear to front. If your problem goes away, you've got a bad tire my friend.
Old 04-21-2009, 06:49 AM
vanste's Avatar
also might be alignment issue too?
Old 04-21-2009, 06:51 AM
kp
kp's Avatar
It probably isn't tire pressure because it started so suddenly, but I've seen worse caused simply by low tire pressure.
Old 04-21-2009, 07:30 AM
Jaz760's Avatar
yeah rotate your tires, and check pressure in them. if that doesnt work, then you need an alignment
Old 04-21-2009, 09:07 AM
seadonkeyraypiss's Avatar
Is it a hard "jerk" to the left? If so, it could be one of your axles.
Old 04-21-2009, 09:26 AM
joelmatt89's Avatar
that doesn't seem like it could be from tire wear or pressure. If the alignment suddenly got that bad you would have had to hit something very noticeable I am assuming since you didn't mention that you probably didn't. Have you tried jacking up the car and putting it in gear with the engine running. From my experience that can really help you narrow down the problem. Don't just guess it's bad alignment because if it's not and then you have to replace something you pretty much just threw 80 bucks out the window. You can easily measure if your alignment is off. Just set up two strings running along either side of the car then make sure they are parallel, then turn the wheel so on the of the wheels is perfectly parallel with the string and measure your other wheel, it should be parallel as well. The kind of problem your talking about would be at least 1/4"
Old 04-21-2009, 04:53 PM
carcious's Avatar
Looks like it might be my steering rack bushings. This sucks, no one here has any in stock. I gotta order from Honda -___-
Old 04-21-2009, 06:01 PM
EricRyan's Avatar
Is your p/s rack moving around down there when you turn the steering wheel or something?
Old 04-21-2009, 06:24 PM
cashkeith's Avatar
the belt in your tire could of went
Old 04-21-2009, 06:59 PM
IhateworkingoncaRs's Avatar
As a former alignment technician, your post is quite interesting. Unless I'm reading it wrong, I believe you are suggesting to measure the toe angle, alignment pulls are caused from camber and caster angles(not so much caster for front wheel drive vehicles).
Old 04-21-2009, 07:00 PM
BuiltCivic99's Avatar
man if you hit something...anything remotely hard you bent your control arm...i did this while doing donuts in the snow in a $15,000 yes i kno it was dumb : ) but its a bent control arm if u did.
Old 04-21-2009, 10:03 PM
carcious's Avatar
YES! I took a look at it today, from the engine bay, and when I turn the wheel I see the rack moving back and forth. I no longer have power steering, but I'm pretty sure it still isn't supposed to be doing that.
Oh and no I didn't hit anything.
Old 04-25-2009, 10:50 PM
turry89si's Avatar
I have the same problem with the pull, only its been doing it for some time i guess, and i was told by my dad i need to pretty much replace the front end completely. i think my car was hit before, but anyway, when driving, if you let go of the wheel, you will instantly go 75 degrees to the left, but it takes no strength to keep steady.
Old 04-25-2009, 10:51 PM
sp00ledbseries's Avatar
Old 04-25-2009, 10:58 PM
turry89si's Avatar
yea i thought of that, cause my moms car had the same deal about a week ago, just no where as bad as this, but he insists its not that, ill run it by him again
Old 04-28-2009, 02:25 AM
carcious's Avatar
So today I finally got it diagnosed.
And I have a few problems,
first the bushings on my steering rack are toooooast.
second, both my axles are broken.
So time to find some axles -_-
thanks to everyone who helped out and gave their two-cents.
dc2long
10-08-2009 08:52 PM
EJ8VTECFTW
Honda Civic (2006 - 2015)
07-10-2007 08:15 PM
jamsicle
Honda S2000
10-11-2006 09:20 AM
LEON
06-30-2002 02:35 PM
slash00R
01-23-2002 06:04 PM
Quick Reply: Car pulling hard left? Help?
