Car Pops Out Of Gear
Old 03-02-2004, 06:25 PM
steve_s's Avatar
Default Car Pops Out Of Gear
Alright guys im hoping you can help me with something. My 93 Civic Coupe with stock engine is popping out of gear.
It only happens when im in second gear and usually when I let off the gas and then get back on it, like when going around a turn it just comes out of gear.
PLEASE HELP!
Old 03-02-2004, 06:55 PM
screech's Avatar
Default Re: Car Pops Out Of Gear (steve_s)
i have the same question happens to me too!
Old 03-02-2004, 07:04 PM
b16 matt's Avatar
Default Re: (Dimi)
Change your fluid. If that doesnt stop it, it's probably your syncros.
Old 03-02-2004, 07:05 PM
overrated.
OnePointFive's Avatar
Default Re: (Dimi)
Check to make sure you don't have a leak, and make sure the transmission fluid is at the proper level. It could be the beginning of a serious problem
Old 03-02-2004, 07:19 PM
GARBhatch.'s Avatar
Default Re: (OnePointFive)
Did you recently do anything with your shift linkage? If so you might not have greased up some of the bushings enough. When I first installed my short shifter with some poly bushings, I didn't use enough of their so called "super grease". It did the exact thing you explain. After taking everything apart again and relubing everything good, it was fixed. But if you didn't do any work on it, I'd say 90%chance your second gear is fawqd.
Old 03-03-2004, 03:33 PM
steve_s's Avatar
Default Re: (GARBhatch.)
Tranny was replaced about 5000 miles ago. But from the get go with the new tranny second gear grinded occasionally when i shifted into it, which means the syncro was going bad. Would a bad syncro be teh cause of this also?
Old 03-03-2004, 03:49 PM
mrctr's Avatar
Default Re: (steve_s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_s &raquo;</TD></TR><TR><TD CLASS="quote">Tranny was replaced about 5000 miles ago. But from the get go with the new tranny second gear grinded occasionally when i shifted into it, which means the syncro was going bad. Would a bad syncro be teh cause of this also?
yes it would be the syncros. i just changed my fifth and reverse....they went bad half way to l.a sucks...
Old 03-03-2004, 06:21 PM
steve_s's Avatar
Default Re: (mrctr)
Um I dont think reverse has a syncro dude, correct me if im wrong, but im pretty sure they dont.
wrx'n you
12-21-2005 08:20 AM
Bond
01-31-2005 07:14 PM
rizq777
09-25-2004 07:57 AM
hookeduphatch95
11
02-19-2004 08:08 PM
unKnown
05-24-2003 10:55 AM
Quick Reply: Car Pops Out Of Gear
