Car Not Starting Up!! HELP!
Ok so heres the dilly. I got a 1993 honda civic DX 2 door. It is not starting up. It rotates but wont fire up. It just turned off while i was at a red light. So I thought initially at first it was the main relay cause as we all know, main relays are always the first concern most of the time when it involves heat. But in this case, the main relay checked out fine. I did a test. Timing belt is fine. The motor is gettin gas cause I smell gas when I try to crank it up. All fuses check out okay. I tried spraying starting fluid in the intake..still doesnt work. Anyone give me something to check...or hae you had a similar problem? Let me know! Thanks.
Daniel
Daniel
Re: Car Not Starting Up!! HELP! (fitchboy22)
Its probably your coil, There as bad as the main relays for just going with no warning. It happened on my car.
Re: Car Not Starting Up!! HELP! (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe »</TD></TR><TR><TD CLASS="quote">Its probably your coil, There as bad as the main relays for just going with no warning. It happened on my car.</TD></TR></TABLE>
what he said
what he said
nismogrendel
04-24-2010 01:43 AM
