car bucking
car bucking
wats god i have a 99 si i/h/e b16. it has 98000 miles on it. 2 days ago it started bucking wen i hit the gas it bucks hard. could it be the fuel filter i havnt changed it since i bought it and i bought it wit 92000 on it. o and my valve adjustment is all fucked up that im gonna be fixing in 2 days. iight thanks
Re: car bucking (EF8IGHT)
you sure when you did the timiing belt that all the marks lined up. put a timing gun on it and see if its in spec. if alls that is good then check the ignitor in the distributor, a bad ignitor will cause a engine to misfire
Re: car bucking (mtownsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8civic93 »</TD></TR><TR><TD CLASS="quote">my guess would be your fuel filter. Check your entire fuel supply, from filter, pump and output.</TD></TR></TABLE>
The problem you describe sounds a lot like fuel starvation Change the fuel filter reff to the shop manual for locations on the car there are normally 2 filters one by the gas tank under the car and one mounted on the fire wall. Always change both at the same time.
Re: car bucking (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote"> a bad ignitor will cause a engine to misfire</TD></TR></TABLE>
but misfiring should cause a CEL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtownsi »</TD></TR><TR><TD CLASS="quote">no codes just changed oil,timingbelt,s/c,p/s beltsspark plugs are good ngks, wires are good msd8.5mm, havnt looked the distributoryet </TD></TR></TABLE>
same thing happened with me and i would say deff change your fuel filter it fixed my prob
ok ima try the fuel filter because the the timing is perfect and the ignition system if good. thanks for all ur help ill let u know wat it is
capm.stabahoe
12-27-2008 06:17 PM
S2k Hybrid
12
04-24-2007 09:41 PM
