cant find a mount to put this tranny in my car
i will post pics in a few min but i cant find any t-bracket that will fit in my car
i put a ls with an s4c trans in my car (2000 civic si) and nothing will make tihs trans bolt into my car... I HAVE A T-BRACKET FROM A DC THAT DOES NOT WORK!! because that is the bracket everyone sais to use and it does not fit onto my tranny...
so i went and bought a DA bracket that did fit on my trans it fit on perfect but now the mount does not line up with the bracket, and since all 88-00 civics use the same rear mount i need to know what bracket will make this trans fit on my car... ive been searching for a week now asking everyone i know nad its like nobody has ever put a b16a2 in an eg before... i thought i might need a bracket from a 2000 civic si tranny but everone sais it wont fit at all..
im stumped
anybody run into this problem im at a dead end
i will post pics in a few min of both a da and a dc bracket not fitting... plus i was looking at a pic of a del sol vtec bracket and it was exactly like the dc bracket so i cant see it working
TIA chris
im stumped
TIA chris
Re: cant find a mount to put this tranny in my car (si0385.)
here is the DC mount see how it fits the top of the tranny and the motor mount nice.. but the bottom bolts of the bracket dont line up with the tranny (19mm bolts not 17's)
this is the DA bracket that would fit on the tranny but the mount is not in the right spot this one is way off with the mount but the 19mm bolt holes lign up on the tranny (tried it when the trans and motor was out of car to double check)
DC top DA bottom
DC left DA right
i know someone out there's gota know whats going on with this its really making me not want the car anymore and because the motor torques so much when i drive it its already making the p/s axle click
some correct me if i'm wrong, but all b-series trannies are the same, they all bolt up to the blocks the same. and if it's going into an eg, then an integra , delsol, or 2000 civic si rear tranny bracket will fit.
try jacking the engine uo and down to position it. bolt it to the tranny first then the mount, and ALWAYS, do this mount first when installing the motor, just makes things easier.
Re: cant find a mount to put this tranny in my car (philosofy1)
Just so you know when putting a motor in that mount/bracket should be the first one to be seated correctly before you do anything else because its a bitch and half. That DC bracket should be fine to work but if it doesnt then a 2000 si bracket is what you need. Dont know who told you you needed a DA
Re: cant find a mount to put this tranny in my car (Luserkid)
usually u need the 99-00 rear bracket if your putting it in a SI
edit - why didnt u reuse your same mounts and brackets from your SI
read this, tells u wat u need for each swap you do
https://honda-tech.com/zerothread?id=983454
Re: cant find a mount to put this tranny in my car (SPNFEDEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH »</TD></TR><TR><TD CLASS="quote">usually u need the 99-00 rear bracket if your putting it in a SI
https://honda-tech.com/zerothread?id=983454</TD></TR></TABLE>
i checked that also and it just sais you have to change the bracket but not to what
Not to be confused with "THE MAN"
I have the same motor and tranny combo you have. And when I put it in if I let the motor hang off the side mounts my rear mount is off just as much as yours. Rock the motor. Or like stated previously attatch that mount first. I've swapped every EG/EJ I have ever owned and my friends and always used DC motor mounts. Try getting a friend to rock the motor forward while you line up the bolts. Good luck.
P.S. if you get them to line up put in the lower one first.
Re: cant find a mount to put this tranny in my car (THE GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GUY »</TD></TR><TR><TD CLASS="quote">I have the same motor and tranny combo you have. And when I put it in if I let the motor hang off the side mounts my rear mount is off just as much as yours. Rock the motor. Or like stated previously attatch that mount first. I've swapped every EG/EJ I have ever owned and my friends and always used DC motor mounts. Try getting a friend to rock the motor forward while you line up the bolts. Good luck.
P.S. if you get them to line up put in the lower one first.</TD></TR></TABLE>
im tellin ya no matter how much i rock the motor the bolts are too close together no matter what i even measured its jsut not possible modifacation to the motor or to the bracket witch im not doing
has anyone used a bracket from a 2000 civic si
see how much longer that DA bracket is that is the one that fits the tranny that DC bracket does not fit at all
Re: cant find a mount to put this tranny in my car (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor »</TD></TR><TR><TD CLASS="quote">i used a 00SI b16 rear bracket to install a b18 into a ek..fits nicely.. </TD></TR></TABLE>
this is goin into an eg not an ek im trying to see if it makes a difference
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. »</TD></TR><TR><TD CLASS="quote">this is goin into an eg not an ek im trying to see if it makes a difference</TD></TR></TABLE>
yo, make some sense and get your ducks in a row before posting or nobody can help you out.
i put a ls with an s4c trans in my car (2000 civic si) and nothing will make tihs trans bolt into my car... </TD></TR></TABLE>
Does that not say 2000 Si?? Now it's an EG. EK's and EG's/DC's will use DIFFERENT rear brackets
Re: (95dxb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 »</TD></TR><TR><TD CLASS="quote">if you have an eg and your using a dc bracket it should fit end of story</TD></TR></TABLE>
true story
true story
Re: (turbociviccoupe)
edit: was the car an auto? if so did you get the conversion mount?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">
true story </TD></TR></TABLE>
x10....hey man just trying to help..u did say 2000 civic si...if u have a eg..that DC bracket should fit no problem.. u prollly did something wrong..double check everything..
Re: (k_motor)
92-95 Manual - 94-00 integra bracket
92-95 Auto - 94-00 integra bracket with Auto to manual conversion mount
96-00 auto/manual - 99-00 Civic SI bracket
Any Del Sol - B16 Del Sol bracket.
Re: (Luserkid)
guy's i am absolutely not a n00b at this and i have swapped atleast 12 eg's with a b series w/ this same tranny. The dc bracket DOES NOT line up...we have tired several different dc's brackets and **** dont work.
What are the chance's of the bell housing being messed up?
Re: (ej1_hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1_hybrid »</TD></TR><TR><TD CLASS="quote">guy's i am absolutely not a n00b at this and i have swapped atleast 12 eg's with a b series w/ this same tranny. The dc bracket DOES NOT line up...we have tired several different dc's brackets and **** dont work.
What are the chance's of the bell housing being messed up?</TD></TR></TABLE>
I have a s4 out of a 2000 SI in my car with a 94 gsr rear mount and I have all the bolts in mine. I looked at all the trannys at the shop yesterday and a DC rear bracket fit every hydro B-series tranny. I checked all models except a S4C out of a CTR, cause thats the only one we don't have. If I find anything out I'll let ya know. I hope you figure it out bro.
Re: (THE GUY)
Oh if it helps any the only car I have ever used a 2000 SI rear mount in is a EK with a b-series. May work in other cars but I haven't found a combo that it would work with yet.
Re: (THE GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE GUY »</TD></TR><TR><TD CLASS="quote">I have a s4 out of a 2000 SI in my car with a 94 gsr rear mount and I have all the bolts in mine. I looked at all the trannys at the shop yesterday and a DC rear bracket fit every hydro B-series tranny. I checked all models except a S4C out of a CTR, cause thats the only one we don't have. If I find anything out I'll let ya know. I hope you figure it out bro. </TD></TR></TABLE>
Word man, i have had s4c's in my eg's before and i have never had this problem. It is mind boggling.
It's not a CTR tranny because it has a factory EM1 vin on it.
flanker
12-08-2014 01:26 AM
vadimqwe
16
03-06-2009 02:29 PM
si0385.
14
08-30-2006 01:23 PM
jDmImagE
10-15-2005 01:18 PM
illmatik
01-12-2004 03:09 PM
