Can low oil pressure cause my fuel pump not to prime?
I have a 95 del sol with a d16z6 1.6 4 cylinder v-tech, and now it takes a while for it to prime (especially on hot days or whenever it rains.) I've pretty much replaced the ecu, main fuel relay, fuel pump, starter and distributor. At this point I feel like taking it to Honda so they can check it out. Any help would be greatly appreciated!!
Re: Can low oil pressure cause my fuel pump not to prime?
My ideas after you've done those things, would be ignition switch? Fuel filter? I just don't know why it would be worse on hot days or rainy days though. They would effect the switch possibly, but not the filter. Also check for a clogged Vtec cylanoid. Maybe even a bad temp sensor. That's my only ideas.
As go250mph says, fuel filter is point one to look at if you haven't gone there yet.
After that, I start by tearing things apart and testing them one by one. the pathway is my first place to look, can the fuel lines flow easily?
Kumpy
10-23-2015 02:35 PM
smileygreasy
15
04-19-2015 07:36 PM
hermtm2
23
04-08-2009 06:17 PM
ek_slut
09-23-2005 02:00 PM
sirex89
05-12-2005 09:59 AM
