Caliper question
Caliper question
Hey everyone,
I recently replaced both back rotors on my 94 Civic EX (1.6L vtec) Coupe, and while the mechanic (whom im close friends with) was working on the car he calls me to tell me the back passenger caliper froze.
I replaced this caliper about two years back, and that makes me uneasy as I don't believe in two faulty calipers.
Thus, the question is, what can cause a caliper to seize up other than wear and tear or a faulty caliper?
Much appreciated for any help!
~Sigma
~Sigma
Re: Caliper question (SigmaOmega)
Honestly for some reason Ive seen most civics have the same problem if they didn't come with rear disc. For the ones that do they just go bad after a while.
probably those were not good calipers. or he is just making some money out of you.. or your brake lines are clogged..try to bleed it!!..and check your brake master cylinder and buster i could be durty!!
Re: Caliper question (sorullo)
thanks, well I changed the first caliper myself because I knew it froze up on me, so I didn't mind accepting him saying that the same spot froze up again lol. But yea ill check those spots tomorrow.
Yea I was going tell you if its swapped rear disc usally the calipers dont get enough pressure so that might cause the problem or if the Master is going bad
Nocturnal
08-01-2005 10:56 PM
dbailey
11-28-2004 06:00 PM
