cable to hydro conversion
Old Jul 21, 2005 | 08:42 PM
4drsleeper123's Avatar
Default cable to hydro conversion
I have a B16 with a cable to hydro conversion on it I was just wondering if there is anything I should know about this when I do the swap. I think I know how it install it but I dont know for sure. I know what some of you are going to say "go get a hydro trans" I will one day but right now I dont have the cash to do it. Thanks for any help I hope to have the swap done next week some time. If you have any pics of this installed I would love you for ever and ever LOL!!!!!!!
Old Jul 21, 2005 | 09:16 PM
hybridmath's Avatar
Default Re: cable to hydro conversion (4drsleeper123)
hasport makes a kit so you can use cable tranny in hydo car i have it on mine
Old Jul 22, 2005 | 08:56 AM
Default Re: cable to hydro conversion (steve6025)
I have the kit on the motor but I dont know how to put it on and what it looks like on the car. Thanks
Old Jul 23, 2005 | 08:17 AM
hybridmath's Avatar
i will try and get a pic of mine its on a cable tranny in 94 hatch
Old Jul 23, 2005 | 11:04 AM
That would be awsome, thanks for the help!!!!!
Old Jul 23, 2005 | 11:53 AM
momstaxi's Avatar
i had that setup in my car for a while...i used a place racing mount made for cable tranny into a hydro car. do you have the plate that holds the cable that mounts on the firewall?
also you need a cable pedal and i had to cut a hole on the top of my gas pedal bracket to allow the cable to go through and attach to the pedal. you will also need to remove/splice together the wires for the neutral saftey switch...
you also need a cable half shaft and drivers side axle, the hydro splines are different that go into the tranny and you will leak tranny fluid. then, i am told that cable linkage will not work on a hydro transmission but i am unsure of this...
hope this helps
Old Jul 25, 2005 | 03:35 PM
hybridmath's Avatar
i wasnt able to fugure out how to post pics so i sent to your email hope they help
Old Jul 25, 2005 | 04:03 PM
typeoneeg6's Avatar
there is nothing wrong with b16 cable tranny's. the feel is definately better with a hydro, but the b16 cable tranny have close ratios that are great for racing. daily driveablity is a pain sometimes. youll be doing a lot of shifting.
Old Jul 28, 2005 | 04:44 PM
Thank you so much for the pics they helped my alot. I will be doing the swap next weekend so pics will be comming your way here soon!!!! Thanks for all the help
bigballing222
Transmission & Drivetrain
Feb 2, 2011 05:18 PM
90efcvicsi23
Dec 4, 2008 10:19 PM
lilo_goki
Apr 20, 2007 11:25 PM
Slowboy!
Feb 25, 2006 08:49 AM
