c.v. shaft problem
Old 08-22-2008, 04:18 PM
JDM_EK_JOE's Avatar
Default c.v. shaft problem
hey i have usdm 32mm hubs and i need to install a jdm itr motor. how do i get the shafts to work with my usdm hub?
also the only way to differ a lsd trannie is to take out the trannie from the block? or can i look through where the shafts go in? the "LSD" stamp isnt on the trannie...
Old 08-22-2008, 04:24 PM
Resident Gearhead
BryanM.'s Avatar
Default Re: c.v. shaft problem (JDM_EK_JOE)
Use regular Integra axles?
Look through the tranny with the axles removed. If you can see straight through you've got LSD. If there's a bar in the middle, sorry, no LSD
Old 08-22-2008, 04:29 PM
JDM_EK_JOE's Avatar
Default Re: c.v. shaft problem (mcvtec)
i dont think you can use regular usdm b series axles, reason being is because the jdm itr trannies came with 36 spline axles..someone please correct me if i can just use ordinary usdm b series axles and if the inners will fit into the jdm trannie..thank you
Old 08-22-2008, 04:33 PM
Resident Gearhead
BryanM.'s Avatar
I think you my be right, my bad
Old 08-22-2008, 04:47 PM
Resident Gearhead
BryanM.'s Avatar
Wait what year is your motor?
Old 08-24-2008, 10:26 AM
JDM_EK_JOE's Avatar
97
preludeNApower
03-06-2013 12:48 PM
BowDownCRX31
09-19-2011 09:15 AM
usmcpab
Transmission & Drivetrain
06-05-2009 09:10 PM
F22PwrdS2k
04-24-2007 01:18 PM
wtsexton
03-14-2004 02:04 AM
Quick Reply: c.v. shaft problem
