c.v. shaft problem
c.v. shaft problem
hey i have usdm 32mm hubs and i need to install a jdm itr motor. how do i get the shafts to work with my usdm hub?
also the only way to differ a lsd trannie is to take out the trannie from the block? or can i look through where the shafts go in? the "LSD" stamp isnt on the trannie...
Re: c.v. shaft problem (mcvtec)
i dont think you can use regular usdm b series axles, reason being is because the jdm itr trannies came with 36 spline axles..someone please correct me if i can just use ordinary usdm b series axles and if the inners will fit into the jdm trannie..thank you
BowDownCRX31
09-19-2011 09:15 AM
