bumpstops for koni yellows?
Old 03-29-2002, 11:59 AM
New User
deviant94ex's Avatar
Default bumpstops for koni yellows?
i just picked up a set of neuspeed koni yellows. i am installing them with integra gsr eibach sportlines. in the instructions it shows the bumpstops at full length, and there is no mention of trimming them. for anyone out there with these shocks, what did you do with your bumpstops. it seems as if i would be riding on them if i was to not trim them. should i cut them in half anyway. thanks for any help you guys can give me.
CHRIS
Old 03-29-2002, 12:37 PM
jonsteR's Avatar
Default Re: bumpstops for koni yellows? (deviant94ex)
Basically you can cut the bumstop to the same length as the progress bumpstop below.
Old 03-29-2002, 01:15 PM
New User
Default Re: bumpstops for koni yellows? (jonsteR)
sweet...thanks for the help.....looks like ill be cutting them in half.....hopefully everything will go in on wednesday night!! thanks again.
CHRIS
Old 03-29-2002, 02:14 PM
DragII's Avatar
yup just to cosign that....half em!
Old 03-30-2002, 11:42 AM
sshaikh01's Avatar
Default Re: bumpstops for koni yellows? (SuperDragII)
i know i'm about to ask a silly question.
What does cutting the bump stop do ??
Old 03-30-2002, 12:23 PM
mantic6t9's Avatar
Default Re: bumpstops for koni yellows? (sshaikh01)
Your stock bumpstops are designed with the oem spring/shock in mind. When you lower your car you effectivly shorten the suspension travel of the car. When the spring and shock are under load and compressed you have less room between the bumpstop and shock body meaning you will moslt likely hit the bump stop on every bump. This can make your suspension too stiff and unsafe on streets, your ride quality will likely be bouncy if you're rideing on your bumpstops.
Old 03-30-2002, 12:42 PM
sshaikh01's Avatar
Default Re: bumpstops for koni yellows? (mantic6t9)
what would happen if you completly remove them.
and ride on just shocks and lowering springs.
Old 03-30-2002, 03:02 PM
robinson's Avatar
If you bottomed out your supension you could do serious dammage to your shocks.
Old 03-30-2002, 04:14 PM
sshaikh01's Avatar
Default Re: bumpstops for koni yellows? (HS killa)
i rode my integra like that. no problem expet for bouncy ride due to cheap springs.
Old 03-30-2002, 08:33 PM
blkwidw96's Avatar
QUOTE]i rode my integra like that. no problem expet for bouncy ride due to cheap springs.[/QUOTE]
wouldn't the bouncy ride actually be attributed to high spring rates with shocks that can't match the rate rather than the actual qualit of the springs themselves.[
Old 03-30-2002, 09:12 PM
nwdave's Avatar
Default Re: bumpstops for koni yellows? (blkwidw96)
Yeah, springs are usually considered bad because of sagging and being weak...not bouncy. That's the strut department.
Old 03-31-2002, 10:48 AM
EVIL Hx Coupe's Avatar
Default Re: bumpstops for koni yellows? (delsolguy)
I have mine with no bumpstops, I think this is why my car hits really hard when I hit a bump.
Old 03-31-2002, 10:51 AM
DragII's Avatar
Default Re: bumpstops for koni yellows? (Boost Pressure)
you guys with no bumpstops are seriously risking the life of your shocks. you need to have at least some bumpstop on your car.
Old 04-02-2002, 03:07 PM
VWkila's Avatar
I'm putting ITR bumpstops on my new Konis and the diameter of the hole in the bumpstop is too small-can't get the bumpstop on the shock. Is it okat to enlarge the hole?
Same problem with the damper mounting rubber. Is it okay to enlarge the hole?
PS:excuse me. I've posted this same topic on ITR forum w/o any sucess.
Old 04-02-2002, 03:09 PM
DragII's Avatar
Default Re: bumpstops for koni yellows? (VWkila)
yeah, it's cool to enlarge the hole
Old 04-02-2002, 03:16 PM
VWkila's Avatar
Hey, SuperDragII!
Thanks for the quick reply! EG+Civic/Del Sol forum rocks!
DC2Monster
02-19-2015 02:29 PM
Vantage
Honda Civic (2001 - 2005)
03-19-2007 05:39 AM
Civicboy
09-28-2002 02:10 PM
taytay333
03-26-2002 03:54 PM
Chairman Kaga
02-14-2002 08:31 AM
Quick Reply: bumpstops for koni yellows?
