building b16 while out of the car...
ok. i got my b16 second gen and its sitting in my garage right now. i got $1500 left over from when i bought it. my friend says i should use the money to build the bottom end and tranny while its out of the car. im just looking for suggestions or things i may not have thought of. i do need lsd though so im thinking about it.
thanx for any help or suggestions.
Re: building b16 while out of the car... (allmtr)
first check all the parts, get new timing belt, check the water pump/oil pumps, replace the spark plugs (if necessary), new rotor/distributor cap, check the seals all around as well...if all is good then move on to performance goods
definatly get Quaife or Kaaz = $800-1000
lightweight flywheel or ITR or lighten yours = $120-350
CTR/ITR intake cam = $250
ITR intake manifold = $250
or
header = $300-400 for DC JDM 2.5" ( test pipe or custom cat)
other choices are ecu chipping, boring out the TB
or
Re: building b16 while out of the car... (DragIIDigital)
thanx for the replys so far. turbo would be fun, but i think i want all motor. yeah, i want all motor.
I have a second gen B16 sitting in my garage too.
Here is what I have/installing:
CTR cams
Skunk2 cam gears
ITR intake manifold
Portflow inner valve spring/ITR outer v.s.
Portflow Titanium retainers
DC header
Re-chipped P28
V-AFC
Exedy Clutch/clutchmaster flywheel
Port and Polish + 3 angle
Along with the aftermarket stuff I bought new from Honda:
Timing Belt
Alternator Belt
Water pump
All gaskets
Fuel Filter
Thermostat
Hope this helps you out.
[Modified by blackANESE, 7:30 PM 6/24/2002]
CTR cams
Skunk2 cam gears
ITR intake manifold
DC header
Re-chipped P28
V-AFC
Timing Belt
Alternator Belt
Water pump
All gaskets
Fuel Filter
Thermostat
Re: building b16 while out of the car... (blackANESE)
wow thanx. that helps alot. i got a pr3 ecu with it. i dont know if its obd1 or 2. i was told 1. but anyways, do you think i should go for a chipped p-28?
I went with a re-chipped p28 to have a little higher redline and have optimized fuel maps. Not really necessary but I wanted it. The PR3 should work fine.
What car is it going into??
you seem to know your shiz. anyways...its going in a 96 civic hatch. obd-2 so its a problem. i know i need the conversion harness.
Future Texas Boy
My suggestion:
Sell the shortblock and buy a GSR shortblock. While it`s apart swap out the pistons for R pistons. Add CTR cams, gears, etc. and tune.
The best bang for the buck is obviously going 1.8 IMO. This is still very reliable, too.
Ryan
Ryan
Re: building b16 while out of the car... (vtecvoodoo)
ohhh..ryan got jokes..i dont even know what to say to that..u always got me in IR too..****..thats what i get for being the token black guy.
but..dont ever call me jarule..i hate that guy.
anywas if u r a baller like ryan source a 1.8 vtec bottom. or just build what u have with all the R goodies!
[Modified by JaeOne3345, 5:35 AM 6/25/2002]
TypeRbuild718
05-07-2007 03:17 AM
