Brake upgrade help on a '92-95 VX
I'm not all that familiar with what is available for the brakes with this particular chassis and was unable to find information through the search function.
Here is what a friend is looking for:
larger brakes
street driven, no road racing
maybe some minor autocrossing
drag racing
The car is in the process of having a B20/vtec installed from his last car...he is going to add in some sort of suspension, and there will most likely be 17's on the car. He has turned to me for some assistance, and now I'm turning to you for assistance.
Thank you,
Austin
larger brakes
drag racing
Thank you,
Austin
Re: Brake upgrade help on a '92-95 VX (95 EJ)
upgrade to front and rear GSR brakes
Re: Brake upgrade help on a '92-95 VX (Austin)
here is a link https://honda-tech.com/zerothread?id=152884
I'm in the process of doing the same thing (mine is a '98 hatch). You can go with either LS or GS-R brakes because they're the same thing. Now if you want to do drag racing, you'll probably want to keep your stock setup in front. Just get better pads and rotors. Because with Integra front brakes you won't be able to run a 13" wheel for slicks. At least not that I know of...
Kannan08
01-14-2012 06:08 AM
