front brakes ?
Old Jun 21, 2002 | 09:25 AM
denieone's Avatar
Default front brakes ?
i already did a search and nobody's problems match mine..............
my right/front is squeaking as hell when i'm driving but it stops squeaking when
i hit the brakes........ this started happening the day after i when road racing.
two nights ago i took the brakes apart, just to make sure everything was fine, and
they appeared to be fine. what else can i do to fixed this damn squeaking?
thanks in advance.........
Old Jun 21, 2002 | 09:49 AM
YeuEmMaiMai's Avatar
Default Re: front brakes ? (denieone)
are you sure a caliper is not dragging? try some anti squeal on the pad backings
Old Jun 21, 2002 | 10:44 AM
denieone's Avatar
Default Re: front brakes ? (YeuEmMaiMai)
i already tried some anti squeal but no luck.
how do i find out if my caliper is dragging?
Old Jun 22, 2002 | 01:42 PM
kyler's Avatar
if you take your hands off the wheel and get into the brakes on a smooth road does it pull to one side? or even without hitting the brakes? if so that caliper might need a rebuild/swap...
Old Jun 22, 2002 | 02:59 PM
Kamin's Avatar
you checked the pads right?
road racing (if you mean track) can kill brakes.
Old Jun 23, 2002 | 11:04 PM
PyroVTEC's Avatar
New User
Jack up that corner of the car that the wheel is on.
Put tranny in neutral (just be sure your parking brake is set if you're testing the front brakes!).
Try and spin the wheel with your hands. It should spin with only very little resistance.
Old Jun 24, 2002 | 01:30 PM
denieone's Avatar
Default Re: front brakes ? (kyler)
_______
no pulling to either side of the car...
yeah i checked the pads they look ok.
i going to replace them with stocker for daily use..........
oh yeah, i went road racing(gingerman)
i already tried this and both front wheels spin fine, very little resistance
this is driving me nut................pretty soon i gonna start pulling my hair off just
like Larry(3 stoogies)
but it won't stop me from going again, well not until i fix the problem(i'm hooked)
road racing =
Old Jun 24, 2002 | 02:17 PM
robbin's Avatar
I had a rear caliper that was dragging but it was really obvious. With the wheel off it was noticeably difficult to turn the hub with my hands and I could hear it scraping. With the wheel on it might not be as noticeable because of the mechanical advantage of applying the force a foot from the hub as opposed to 2 inches or whatever.
-Chris
dc2LS
Oct 20, 2010 06:25 PM
See Are X
Jun 1, 2003 02:51 PM
blkbeast
Apr 18, 2002 07:54 AM
Kamin
57
Mar 20, 2002 10:55 AM
