brake swap
brake swap
Whats up fellow honda-techers I was wondering if someone could give me a parts list for everything I need to do the GSR to Civic brake conversion I need the parts for the front and rear so I know exactly what to get this weekend at the junkyard.I've tried to search but I couldnt find exactly what I needed so any help would be great thanx
Re: brake swap (raver01x)
Didn't search hard enough. E-brake cables, and the whole brake assembly (Spindles etc) to be safe. I am not sure if the e-brake cables are the same or not. The rear trailing arms are the same (if you are talking about '94-00 Teg and '96-00 Civic), as the Teg ones on my car were bent and I was able to use the Civic ones.
-Shane
P.S. New prop valve and m/c is good according to most people, although I still have the Civic ones and it is still way better.
-Shane
Re: brake swap (nighttrain33)
*Edit* Si rear brake assembly should suffice. Same applies though. Except that you can use the Si prop valve and m/c.
-Shane
-Shane
is there a master parts list archived somewhere im searching still now but cant find a list of everything needed I want to get it all in one go
Re: (raver01x)
And I am telling you. Rear trailing arms are the same, just get the spindles, calipers, discs, pads, etc and you will be fine.
-Shane
-Shane
Re: (raver01x)
https://honda-tech.com/zerothread?id=1069787
Just in case you would like to look. There were 109 theads under my search. I think it was rear disc swap, but not sure. ebeer Sunday!
-Shane
-Shane
yeah my search for brake conversion pulled up like 585 topics but I havent found a topic yet with the complete list but I,ll keep searching its here somewhere
Re: (raver01x)
I'm telling you that what I already said you need is it. I did the swap in my ek, and the parts list is the same for an eg. Good luck!
-Shane
-Shane
Cap'N Chronic
03-27-2022 07:16 AM
mikey1992
05-09-2010 07:35 AM
