Brake Problem after relocation
So I recently relocated brake lines using braided hoses and there are no leaks and the pedal has no give but with the car bled multiple times the brake pedal goes almost to the floor. The car stops fine and I can make the tires skid if I want but the pedal goes almost all the way to the floor especially with the booster vacuum line hooked up and has me worried. The booster and proportioning valve are stock but the lines and the Master cylinder aren't. The master cylinder is something I had laying around its a 1 in and I believe its from an integra or something similar. My question is could the length of the lines have something to do with this or is it because I used a different master cylinder
If you loved me, you'd all sell me your magic cards to me today
Re: Brake Problem after relocation
Could you give us more information like the type of car, wht you did exactly, any other information on the stuff you used, some pics?
Assuming you did everything right, the master cylinder would be shot. Again, you could have made a mistake somewhere. I hear about it and see it a lot now. People mingle with their brakes and botched 1 tiny detail, causing the most important system on the car to fail.
STN_Pat
03-20-2009 10:55 AM
dxhatch92
01-16-2007 08:13 PM
sporkcrx
01-10-2003 09:57 AM
