vacuum leak at master cylinder/brake booster?
theres a noticeable hissing sound of a vacuum leak near the bottom of the master cylinder/brake booster. would problems would that cause? and also what would i need to fix the problem
Re: vacuum leak at master cylinder/brake booster? (dxhatch92)
You will probly have to replace the brake booster. You will have a really stiff pedal, and your brakes will not stop you well without alot of pressure.
In other words, there is eather a leak in your brake booster or you just have a crack/cut in the vacuum line going to it.
PS..if you have zero money, and there is a crack in the booster itself, sometimes JB weld or even duct tape will work as a temp fix.
Specail Ed
03-31-2008 08:25 AM
