bottom end build
bottom end build
im building my LS motor for about 15-22 psi currently i am doing the bottom end right now, the entire motor is ripped about down to just a bare block and i just got my weisco low compression pistons and eagle rods and i plan to have it bored 20 over here in a week or so then send it to get sleeved. Any ideas on what else i should do to the bottom end?? or any good ideas to do to the head??thanks
Re: bottom end build (J_M_B)
well wit the new pistons and rods. get new bearings as well. while ur doin all that replace ur timing belt, water pump and oil pump, all gaskets of course. and new valves for the head.
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_M_B »</TD></TR><TR><TD CLASS="quote"> i plan to have it bored 20 over here in a week or so then send it to get sleeved. Any ideas on what else i should do to the bottom end?? or any good ideas to do to the head??thanks </TD></TR></TABLE>
yeah you might wanna sleeve it before you bore it 20 over..lol, but yeah all bearings, block gaurd, arp head studs, hondata intake manifold gasket keep intake cooler. and there are tons of things you can do to the head. Id do somthing...i know to many people with fully built bottom ends that dro pa valve and ruin everything.
B A N N E D
search for them, some brands, ACL, TOGA.....
here is a site tehat was in my favs http://www.tunerschoice.com/xq...t.htm
Re: (DecentCivicZ6)
remember to measure/plastigauge maincaps and rods, write measurement down on paper, and order your correct size/color bearings.
GreddySi99
09-27-2003 06:44 AM
