Rear Brakes barely touch rotor on '00 Si
Old 10-06-2010, 05:26 AM
dkrangers's Avatar
Default Rear Brakes barely touch rotor on '00 Si
Vehicle: 2000 Civic Si with just over 100K on the clock
So for awhile now I've been dealing with rear brakes that hardly work and from an autox and future track day stand point this isn't good.
I've had a mechanic friend tell me its a typical issue with honda's and I shouldn't waste my money. I had one seized caliper and I replaced that and it didn't do much to grab the entire rotor, the pad only grabs 1/4 of the rotor now. The other side grabs even less.
I'm to the point where I'm considering replacing the brake lines with stainless, the calipers with new honda units on both sides and even considering the master cylinder... I just want these to work as intended!
Any advice? I'm currently running powerslot rotors and hawk pads but everything else brake wise is stock.
BTW, everything is properly lubricated so it's not the slides. The system has been bleed multiple times, has plenty of fluid yet when I press down on the pedal its easy to make it go to the floor...
Old 10-06-2010, 08:47 AM
sk8shorty012's Avatar
Default Re: Rear Brakes barely touch rotor on '00 Si
I'd make sure there aren't any leaks in the system. If the pedal is going to the floor there's either a leak / air in the system. A non-stiff pedal will cause the pistons of the calipers to not fully engage. Check your master cylinder (the unit itself) as this is a very common cause of a sinking pedal.
Old 10-06-2010, 08:49 AM
kaiba's Avatar
What kind of brake fuild?
Old 10-07-2010, 05:27 AM
dkrangers's Avatar
There isnt a leak in the system because after bleeding the brakes I top off the fluid and it hasn't gone down at all. Brake fluid is stuff from parts store, not the cheapest but not the most expensive either.
Old 10-07-2010, 05:35 AM
Jockone's Avatar
Does this happen on both the inside and outside of the rotors or just the outside?
Old 10-08-2010, 05:39 AM
dkrangers's Avatar
its on both sides.
Old 10-08-2010, 08:38 AM
Crazy Honda Guy
Deetz's Avatar
I have the same mileage on my EM1. I had a problem with my ebrake even working, not sure how well the rear brakes themselves even worked. But, like many rear disk setups, after time, the calipers can stick and not work properly even with adjustment, so i bought new ones.....problem solved
Old 10-08-2010, 07:13 PM
dkrangers's Avatar
Deetz, did you do anything other than new calipers? Change the brake fluid, SS lines, etc?
Old 10-08-2010, 09:49 PM
Master Detailer
98civdx's Avatar
My old calipers did this. I changed the rear calipers, rear brake lines, and brake fuild and then it was fine.
Old 10-09-2010, 04:13 AM
Anon51's Avatar
mine did the same aswell. just changed both calipers and brake pads and they were fine.
Old 10-09-2010, 08:21 AM
chiautorepair's Avatar
I upgraded mine's to RSX rear calipers and never had that problem again...those calipers are common failure
Old 10-09-2010, 08:22 AM
dkrangers's Avatar
okay, I guess new calipers, fluid and lines will be added to my winter list. Thanks guys.
Old 10-09-2010, 09:47 AM
hillssol95's Avatar
time for new calipers!
Old 10-09-2010, 01:09 PM
speedoptions.ca's Avatar
I know that your car is 2000, but that's still about 10 years. If the pedal is going to the floor I would suggest that you check your master cylinder, and read my other thread about this issue here. your seal may be going out from your constant bleeding https://honda-tech.com/forums/suspension-brakes-54/how-bleeding-old-master-cylinder-can-increase-failure-rate-2846980/
1993gsrcivic
04-19-2008 10:20 PM
vortexx
18
08-28-2006 08:44 AM
siblue_gzer
17
08-23-2006 02:24 AM
robbin
05-07-2002 12:55 PM
Quick Reply: Rear Brakes barely touch rotor on '00 Si
