bend valve
i'd say check the timing again. Same issue when we replaced my buddies head gasket and timing belt on his b16a3. couldnt get it running, but called a friend over to redo the timing and that got the car to fire right up.
if you have access to an air compressor, i would forgoe the compression test and do a cylinder leak-down test. you'll get a better idea of what exactly is leaking, if anything.
compression test just gives you four numbers.
leak-down test will actually make a hissing sound in the intake, exhaust or both depending on which valves are bent or leaking. it will also show how bad the leak is and catch leaks that compression tests won't.
don't let it beat you..!
Y2KCivicSiR
May 9, 2005 09:56 PM
DamonBoost
Sep 28, 2001 12:42 PM
what motor is it? need some info. the timing is probably set wrong
