b20breplaced, water pump.and i bought a 170 thermostat. why is my car still heating up when i throw
Old 09-01-2007, 11:59 PM
* B A N N E D *
mustang5.slow's Avatar
Default b20breplaced, water pump.and i bought a 170 thermostat. why is my car still heating up when i throw
on the title states it all. i replace both the water pump and bought three thermostat 170 degrees being the best one...
now when i throw in the thermostat in my b20b the top hose heats up ant the bottom doesn't and my car heats up. why is it doing this.????
do i have a hose connected wrong or something.??
some body please help. what could it possibly be??
Old 09-02-2007, 12:28 AM
* B A N N E D *
Default Re: b20breplaced, water pump.and i bought a 170 thermostat. why is my car still heating up when i th
bump because i am really desperate
Old 09-02-2007, 12:39 AM
* B A N N E D *
oh BTW i hooked up my fan to be on at all times...
so that is not hte problem.
Old 09-02-2007, 01:38 AM
93 EG's Avatar
have you checked your coolant lately?
Old 09-02-2007, 05:40 AM
racehesh's Avatar
Old rad that isnt cooling properly.
Old 09-02-2007, 10:38 AM
* B A N N E D *
**********coolant level is constantly cheched.'
radiator is good. '
thanks for the input tho.
Old 09-02-2007, 01:32 PM
SMOOTHN's Avatar
Mines did that after my b20 swap... I think its my thermostat not opening all the way... But I added one of those aftermarket temp. Sensor and it works fine now... It even had a relay I could hook up a switch to to turn on and off the fan... So if my car starts to overheat and I flip the switch and nothing happens then I gotta check the relay or fuse... Worked for me... But you said your fan stays on so then just check your thermostat sensor...
Old 09-02-2007, 01:39 PM
* B A N N E D *
what a thermostat sensor...what does that do? i thought a thermostat was activated by water temp.
where is this sensor and how can i check it.??
Old 09-02-2007, 01:51 PM
SMOOTHN's Avatar
I believe its a sensor on either your water pump housing or themostat housing... Your engine wire harness should plug into it... Ill yet to get a pic of it when I get home...
Old 09-02-2007, 02:00 PM
Luserkid's Avatar
His talking about your temp gauge sensor. Thats the little 1P plug thats on the side of the head.
Have you tried running the car without a thermostat?
Old 09-02-2007, 02:28 PM
* B A N N E D *
well i run the car without a thermostat for the mean while but the car will still heat up and keep the fan on.
the car does still heat up but only when i drive in the heat. if i drive at night it doesn't heat up as much. except for when i'm on the freeway for more than like 20 minutes then it heats up.
***so then does that sensor make thermostat open or is it suppose to open with the temp.???
Old 09-02-2007, 03:32 PM
SMOOTHN's Avatar
that sensor opens the thermostat...
Old 09-02-2007, 03:41 PM
Luserkid's Avatar
Default Re: (SMOOTHN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMOOTHN &raquo;</TD></TR><TR><TD CLASS="quote">that sensor opens the thermostat...</TD></TR></TABLE>
What type of thermostat are you running? Thermostats run off a spring system, when it reaches a certain temp the spring opens which allows the coolant to flow.
Sounds like you have a headgasket problem.
Old 09-02-2007, 03:45 PM
95ProjectEJ1's Avatar
Default Re: (Luserkid)
^^ What he said. If you have even a crack in your HG exhaust gases will exit into your coolant.
Check your resevoir for any black film and have your gf stand behind the car while you rev it up. Thats how I found out my HG was poof!
Old 09-02-2007, 06:26 PM
HeikDiesel's Avatar
Default Re: (95ProjectEJ1)
you can also run the car with the cap off the radiator and rev the engine a little bit. If coolant goes everywhere, you have a HG problem
Old 09-02-2007, 08:36 PM
* B A N N E D *
what other ways can i check if it's the head gasket and how can i replace it is it a big hassle.
Old 09-02-2007, 08:38 PM
Default Re: (mustang5.slow)
Compression test.
Its going to cost you about 65 dollars in parts (head gasket, VC gasket) and a thing of coolant. If you dont have the right tools I would take it to someone.
Old 09-02-2007, 08:44 PM
* B A N N E D *
cool thanks for your answers. is ther a DYI on here.
Old 09-02-2007, 08:48 PM
Someone started a thread asking for a DIY, one person replied with this site http://www.jdmlyfestyle.com/my...s.htm
Its a list of write ups. I think the one for the HG is for a DOHC, but captures the basic concept. You are going to need a crank pulley tool or air tools that flow the right CFM needed.
EDIT: And if you find that its not something you want to do, PM Luserkid. He took care of mine last weekend for me.
Old 09-03-2007, 05:02 PM
* B A N N E D *
oh cool...but i have checked all ui could and it doesn't look it is the head gasket. what else could it be.??
Old 09-03-2007, 05:40 PM
Try and run a compression test.
Old 09-03-2007, 05:56 PM
* B A N N E D *
how do i do that.?
Old 09-03-2007, 06:06 PM
You have to purchase a compression tester. Best bet may be to just take it to someone. If you have replaced the thermo and waterpump and your fan comes on there isnt much else you can check. Maybe a leak or a clog, but other than that maybe its the HG. I didnt think my hg was blown, but it was.
Old 09-03-2007, 06:34 PM
HeikDiesel's Avatar
doesnt coolant flow from top to bottom? IF that is the case if coolant is really hot up top and really cold on the bottom the radiator isnt letting coolant flow as fast as it should and that causes it to overcool and make the lower hose cool.
Rein4st
04-07-2012 11:17 AM
Akai Star
04-14-2010 05:29 PM
yz125rider21
11
08-09-2006 04:42 PM
twenty
07-21-2005 08:36 AM
spart
02-27-2002 04:07 PM
Quick Reply: b20breplaced, water pump.and i bought a 170 thermostat. why is my car still heating up when i throw
