b20b Non vtec launch / shift points
Ls took a ****, and just wanting to get to know this a little better from anyone out there. im using my ecu, and rev limit is at 6500..
Re: b20b Non vtec launch / shift points
ok a stock b20 will stop making power around 5800 due to the compression ratio .... the head will not make the power but i have build a b20vtec and with it being built i only turned it 8500.....any other questions just ask...
theres 2 types of b20s a b20b in the usdm format is a 8.8 comp engine that makes max hp at 5400 a usdm b20z makes 146hp at 6200 with 9.6comp if you buy from a importer they are all b20b's just buy a 99 or newer jdm b20b they too are the 9.6comp eng most engines will start too lose too much hp 3-400 revs above max hp rpm. so in this case rev a b20b to 5800 and a b20z to 6500rpm and ur good.
oh and i usually shift at 5600-5800 and it pulls pretty hard for a stockerrrr lol and b20b makes 126hp* and i believe 96+ model was 146+ish correct me if im wrong im going to the dyno on friday!!!!!
i have a stockish b20b and i put my rev limit at 6k.....i didnt find ANY use for the motor to go over 6k.....besides death that is....LOL anyway just my $.02
