B20b Ecu And Harness Question
im gonna swap a b20b into my 97 cx hatch and i was wondering since its obd2 would a obd2 p75 ls ecu plug right in or do i have to get a different harness? and it will work with the b20 right? and also will the DA integra axels work for a b series swap or do i have to use the 94-01 integra or 99 si ones cause i got some off of a da thanks in adv.
Seagull Management
Re: B20b Ecu And Harness Question
You can use the P75 as long as it came from a '96 - '99 Integra ('00 - '01 Integras are OBD2B and also have an immobilizer in them)
As far as the axles go, yes you can use DA axles, but you will need to use a '90 - '93 Driver's side axle seal in the transmission. And a '90 - '93 Intermediate/halfshaft
