b18c Swap in 92 Hatch need some info
i was just wondering if i had to re wire anything for this swap i got the ECU tranny axles and everything else its just a matter of connecting everything but i was wondering if i had to wire anything special for the Vtec??
Re: b18c Swap in 92 Hatch need some info (drpepper)
Your car is prewired for VTEC, you will need to run a wire for the knock sensor if you use an ECU other than a P28. Then you need to repin the IAB from A20 to A17 if using an OBD1 P72. Oh, and your oxygen sensor if your car is a CX or VX.
