b18b1 swap no start
Old 12-20-2014, 08:50 AM
harley78's Avatar
Icon2 b18b1 swap no start
Im, new to the site, hopefully this post is in the right place. I have a 95 coupe ex with b18b1 swap. I have spark, timing, compression, and fuel pump all are good. Also put new plug, new main relay, and tried to different ecu, and still no start. I've noticed there fuel running out of the headers. I don't have exhaust connected yet. And the cylinders are flooding with fuel causing motor to lock up. What could be going on? Thanks
Old 12-20-2014, 08:53 AM
Former User's Avatar
Default Re: b18b1 swap no start
Is this a new swap that has never run before? What ECU?
The fuel injectors are likely stuck open. How are they wired to the ECU?
Old 12-20-2014, 11:21 AM
harley78's Avatar
Yes new swap, never ran. It has the ls ecu. How do I check if injectors are stuck open.also exhaust is not connected, will that affect it not wanting to start. Don't know if it need back pressure to start.
Old 12-20-2014, 11:31 AM
Remove the fuel rail with the injectors. Do the injectors spray fuel when you turn the key from OFF to ON(II) without cranking the engine?
Old 12-20-2014, 11:36 AM
harley78's Avatar
I will be home in aa hr. I will try that. I have checked them for power and pulse, so I know that is working. And if they are not spraying what else might it be?
Old 12-20-2014, 11:38 AM
The injectors should not spray with the key in ON(II) - only in ON(III) when engine is cranking.
Old 12-20-2014, 11:58 AM
harley78's Avatar
Friend just checked it out. They are not spraying in ii postion.
Old 12-20-2014, 12:04 PM
Is spark bright white at all 4 spark plugs?
What are the compression numbers for the cylinders?
Post pictures of the cams and crank with the engine set at TDC1.
Old 12-22-2014, 03:12 AM
harley78's Avatar
Figured it out. It was the fuel pressure regulator that was causing the issue. Thanks for all the imput.
lifethinker
04-21-2014 01:04 PM
littleprophet13
02-15-2010 07:47 PM
laoboisosilly
14
07-14-2009 06:01 AM
posjr
11-22-2006 04:40 PM
Quick Reply: b18b1 swap no start
