b18b1 swap no start
b18b1 swap no start
Im, new to the site, hopefully this post is in the right place. I have a 95 coupe ex with b18b1 swap. I have spark, timing, compression, and fuel pump all are good. Also put new plug, new main relay, and tried to different ecu, and still no start. I've noticed there fuel running out of the headers. I don't have exhaust connected yet. And the cylinders are flooding with fuel causing motor to lock up. What could be going on? Thanks
Re: b18b1 swap no start
Yes new swap, never ran. It has the ls ecu. How do I check if injectors are stuck open.also exhaust is not connected, will that affect it not wanting to start. Don't know if it need back pressure to start.
I will be home in aa hr. I will try that. I have checked them for power and pulse, so I know that is working. And if they are not spraying what else might it be?
Is spark bright white at all 4 spark plugs?
What are the compression numbers for the cylinders?
Post pictures of the cams and crank with the engine set at TDC1.
lifethinker
04-21-2014 01:04 PM
littleprophet13
02-15-2010 07:47 PM
laoboisosilly
14
07-14-2009 06:01 AM
