b18b in 96 hatch ECU options?
you dont wanna get a vtec ecu since your not running it. unless your going ls/vtec. just go with the ecu that belongs to the engine. can go wrong with that.
Re: (mistaashby12)
itll work but its best if you buy a ecu that belongs to the head that you are using. you are swapping a b18b so the ls p75 works for that perfect. if later you make it a ls vtec, thats when you want to change it to whatever head you use. use the ecu that belongs to the head. simple.
Re: b18b in 96 hatch ECU options? (mistaashby12)
im guessing it is not ls-v, the ecu you will need is a p75 ecu and if you want more power get a pig tail and a obd1 p75 chipped or a po6 cihpped.
that works too! im thinking he wants the car running tomorrow or something. any ecu will start it and drive aslong as its a mt. but to have it running perfect you need a p75. odb2a. done!
