B18 ticks when cold. Water pump?? (solved)
So I just dropped a 96 b18b1 into my 98 ex, and there is a horrible ticking noise that coming from the some where on the water pump side of the motor, but it goes away once it gets up to temp. At first I thought it was just cause I needed a valve adjustment, but I did that and it wasn't it. The only things I can think it might be are the water pump (can't remember if it's a Honda oem one or a cheap schucks one), tensioner pulley or crankshaft positioning sensor. Any ideas on what it might be?
Re: B18 ticks when cold. Water pump??
If it's not the valves then use an automotive stethoscope or a long flat head screw driver against your ear and see if you can pinpoint where it's coming from.
civic_tuned
23
07-26-2005 08:42 AM
