Is it normal to see a different sized Spark plug in a del sol?
OK i was changing my spark plugs in my 94 Del Sol Vtec. While installing the new ones i noticed that the 1st plug(closest to passenger side) wasn't catching thread. I then noticed that the spark plug i pulled out was bigger than the one im putting in. The rest of the plugs caught thread fine? IS this normal?
Location: On the road...generally in the central United States...
Re: Is it normal to see a different sized Spark plug in a del sol?
??? Sounds like someone stripped out the hole and tapped it for an oversized spark plug ???
If so, I'd be looking for a new cylinder head.
^^something around that.
a del sol is just a different body style civic to a T.
so no it isn't normal nor is it good.
Your situation is certainly not ideal but if you can find a plug like the odd ball that came out then simply replace it and you'll be good to go. Otherwise as was already mentioned you would need a new cylinder head to fix it.
Yeah i figured they either just put a large plug in there or the helicoil came out with the plug =/ Think i'm just going to sell the car before more problems arise. Thanks guys.
Is this a helicoil? Spark plug problems!
Hi everyone. I've posted before asking about spark plug sizes but i guess that thread was deleted or i would have posted there. I finally got pics of the spark plugs. If anyone could tell me a quick fix or some options that i have it would be appreciated.
The top plug is clearly bigger around and has carbon build up like a ****. I'm sure this plug is one of the reasons my car doesn't run as well as it should.
The Grumpiest
Re: Is this a helicoil? Spark plug problems!
You didn't look very hard AND already got your answers in this post.
https://honda-tech.com/forums/showthread.php?t=3030955
DelSol63116
22
03-25-2014 07:13 PM
