b18 swap=stallng and poor idle??
Ok its a bone stock b18b for the most part and it starts and idles relatively ok (kind of lopes) except for when it warms up then the idle will fall to zero and the car will die.
Im running uberdata with a chipped p28 with a stock ls .bin with no ELD and closed loop disabled because I have no o2 in yet. The only code it throws is a code is a code 20(ELD).
I’ve calibrated my TPS to .46 at idle (4.9) at WOT. I did a compression test (to rule out a bent valve) which yielded 190 (give or take) across the board.
I’m at my wits end here and I’m running out of ideas for things that could be wrong. I need some ideas guys. Let me know what you think.
EDIT: Also I checked the plugs wich are a dark black which would indicate its running pig rich, although that doesnt explain the weak vacuum.
Re: b18 swap=stallng and poor idle?? (5.0 Killa)
Im having the same problem what I did as a quick fix was adjust the idel screw on the throttle body. Are you throwing any codes? You might have somthing different from me.
Re: b18 swap=stallng and poor idle?? (fasthatchb18c1)
I tried the idle adjustment screw and it doesnt do much, I even tried turning up the idle on the .bin but to no avail. The only codes it throws is a code 20 (ELD) which shouldnt effect anything.
Glocked1
12
01-22-2004 08:13 PM
