B16a2 Probs Once Again
Ok so heres the deal
i just swapped a b16a2 into my 94 coupe and im trying to figure out why its not getting gas
ive checked plugs, grounds, injectors, hoses and im coming up with nothing
it will run if i spry starter fluid into it but then dies after it runs out
fuel pump is coming on too
now the bad part
i bought the car off of a lazy friend who let the car **** for 3 years roughly and he left gas inside of it
ive empied most of it but i think there may have been more in the lines
i have filled the tank with good gas tho
now the bad part
Re: B16a2 Probs Once Again (sanegb16)
yea, take the plugs out and leave it open for a while...if the engine has sat for a while, make sure you do the normal start up stuff. Honestly, disconnect the fuel filter, have someone turn on the pump and see what comes out of the line.
so you mean drain the gas out of the rail...just take the rail off, be careful of the injector clips...is that what you mean?
Re: B16a2 Probs Once Again (gottabfast)
im going to redrain everything and see if it works if not back to step one
lol this is my first engine swap and honda im still kinda new to it so bare with me
A little seafoam in the gas should take care of any remaining bad gas. My friend bought a crx that was sitting for like 6 years at a car audio show floor. What he had to do was remove the injectors (probably electrically fine), remove the o-rings and soak the injectors in fresh gasoline overnight to unclog them.
sanegb16
09-22-2007 08:41 AM
