B16a vtec not engaging, need other ideas as to why?
Hey H-T. So my vtec has just stopped working all together. I don't here it crack at 5500. I have correct oil levels, and I'm throwing code 11 which has to do with the IAT sensor. When I think back, it stopped working after I unplugged the sensor from the thermostat so I could wire the radiator fan to a switch. Could this be the culprit? That's the only other thing I could think of. My speedo works, same with the RPM's. Any input would be appreciated!
The Grumpiest
Re: B16a vtec not engaging, need other ideas as to why?
So if I understand this right, you started throwing a code, after you bypassed the IAT to wire the fan to a switch and then VTEC stopped working. And you're wondering if that's the problem? I think you answered your own question.
Sorry for not being clear. I haven't done anything to the IAT sensor. I unplugged the fan switch and made it to where the radiator fan would run whenever I switched it on.
I just checked, the oil is actually over the second dot by like 1/2 inch.
Its in a 94 civic ex and the b16a is second gen. The ecu is a chipped p28.
I did that and it was fine. Could it be the vtec solenoid itself?
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
check everything in here first
If it was your vtec solenoid it would have thrown code 21 or 22 for pressure switch,
Double check the wireing.
